The best thing to do is find out who the OIC is for all the divisions in perth. May seem like pointless name dropping but it helps if u are speaking with a cop set to make an example.
"hello officer......i actually let Snr Const balh balh know of this event just for safetys sake, we are on ure turf after all blah blah, fluff fluff"
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeh but u dont need to actually do it. Thats what im saying.
U just find out the name so u can drop it but dont speak to the OIC and say "hello if ud like to bust some ricers we will be here at this time and this is our map" its been done b4 and it never turns out well.
Thats why maps are no longer public like they used to be. Too much heat on the forums now days
Originally posted by Nizmo
well when u come back from a cruise bearing your yellow stickers and bitching about getting your car over the pits - there will be noooo sympathy from me - you were asking for it!
for the last f*kin time, read what i'm talking about...
I'm NOT talking about giving them maps.. I AM talking about discussing cruises in general with them to find out their opinions on them and to find out how to organise better ones that don't attract attention and therefore cause us no grief...
GET IT????!!
:D
i think hes getting antsy :D
Cops arent gonna tell us how to beat them. Overall its best to just go about our business and keep them out of it. U play the game every time u are on the road. Another excellent tool is a scanner. We avoided a fair bit of police attentin with one of those a fw cruises back. Apparently someone heard they were trying to set up a block for us at captain munchies.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
