  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Couldnt have said it better myself.
Some ppl wont even meet and greet at cruises and thats not really the crew we want. The early cruises were good cause we would get around 12 cars and they were all regulars. Ken adam32 adamq skyzerr joe gradenko radium myself etc etc
Plus u can trust ppl not to ram u in teh ass which is more then i can say for big cruises where i dont know any1.
Originally posted by Nizmo
yes - cos cops have a lotof experience in organising car cruises :D
sheesh - such a dumb idea - wasting breath just discussing it!
thanks for the insightful, helpful and positive feedback niz.. very inspiring..
boost & paul - the only reason i'm for the idea is that on bike cruises general info from the cops was very very helpful.. it also helped that we had a few cops in the group as they could tell us in advance where the problem areas were and what to stay away from...
was just suggesting that sort of insight would be useful applied to car cruises..
i'm all for the smaller cruises over the big ones for the reasons boost listed.. rather have a super happy fun small group than a big tailgating angry group.. :D
Yeah, but the SAU cruises, without other clubs are still quite tight-knit:D
Cam, I agree, if we can try and avoid going through the areas like Freo strip etc, then the cops wouldn't stress so much. We don't want to cause trouble.
See'ya:burnout:
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
