Well mothers day was very slack, Troy and i didnt get up till 1 thisarvo, went to mums, came home and then i took troy boy out to dinner for his bday but i fell down the stairs at my house on the way and im really sore :) We had a booking for 2 but i ended inviting my mum and sister and they couldnt fit 2 more on the table, even though they managed to seat a groups of 4 or more while we where waiting for our take out that we ended up getting from the aisn restaurant. We yelled at them for that. Not going back there.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
no he didnt. My sister did but. Mum was really worried about my back and troy was behind me (he didnt push me) so i didnt see if he was smiling though and holding back the laugh. It was a pretty bad fall and troy boy picked me up. My ankle is slightly swollen. I should be ok. Going to have some wopping bruses though.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
