  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
you shouldnt be touching noone Ken - your wife would kill u!
I have a very open marriage.
If I touch anyone and she finds out , the front door will be well opened ...
Cheers
Ken
I'm sure we could find some temporarily unused stretches of available bitumen, I was actually told to go out there by the local constabulary so I could do what I have to do where no one could see me, as far as accomodation there is budget accomodation around onsite vans / motels / pubs, I could get a reasonable amount under cover( under corrugated iron patio) if they were prepared to swag it, but you would need more than a sleeping bag . if your keen, give me approximate numbers and I'll make enquiries, would be good to see you.
haha premonition eh? well just as well u didnt go :P
Although i had a dream i got a yellow sticker as well but that was ages ago!! I was telling u guys about it on the way up to mickos one night.
Originally posted by SHUTO-BOY
heheh oh im turning 20 soon too, explain why its a downward spiral ken
Because your no longer a teenager. Am expected to start to act responsibly. Your parents will start saying things like
* when are you going to settle down. Do you have to go drinking EVERY night *.
16 year old girls go *ewwww* when you try and con them up.
Heaps more but alschiemers ( which I've had since 22 ) has kicked in.:P
Cheers
Ken
when i was 16 i was going out with a 22 year old i didnt go ewww haha!!
I want my own apartment - ive been thinking about it a lot lately and the urge to get my own "pad" has over taken the urge to do up my car - weird!! I'll buy one if i get the job im going to apply for and save up :P
Don't think swagging would be on the agenda but the bitumen road stuff sounds interesting. Any area of bitumen for circle work , ie large m/khana type area.
Cheers
Ken
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
