Whoretown WA
skyzerr33
 Share
See ya Joe
I will talk to steve again next week about it. I checked the NGK website earlier & it said the same thing about a car with an ecu needing the resistor type (4ohm btw macka).
Said something about issues with idle, etc, etc.
Funnily enough there seems to be a miss at idle, but I took the car out for a lap between showers & it does seem to go better with the new plugs.
Also noticed that the rev limiter on the mines ecu is set somewhere between 8500-8800rpm. Strange thing is I never noticed that before cos I was sure that it was cutting in at 8200 as per the stock ecu that I had:confused:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
That should be bloody good fun Ken.
What time is it cos I got nothing on in the morning so I might come out & watch.
Behave yourself Clinton...you are not really in a position to throw stones
Be careful about revving to 8800. The rods and or bolts have been know to part company if you buzz a std one to 9K on a regular basis.
I usually find it's all over by 7500 anyway.
Cheers
Ken
All day starting at 9am at the racetrack.
Instruction sess in the morning and hot laps after lunch.
I won't be taking any R's up cos one is at CRed and the other is going for pre sale inspection Tuesday.
Cheers
Ken
Should be interesting if it rains next weekend ken.
Would you still run the day if it is wet?
Shit yea, best time to run em.
Plenty sideways action with no tyre wear.
Cheers
ken
Originally posted by macka
It was probably A MISFIRE THAT STOPPED U AT 8 gS
u talkin about plugs or injectors...
mes thinking ur confused with injctors...
Huh ??
Cheers
Ken
Ken......whoopde friggin do :P
Ya micko i agree on that one...
Just because the rev limit is raised doesnt mean your capable of taking it that far.
8500 is what hondas do...(ok 9) and suzuki gtirs ;)
Nah , don't want to scare you and besides , car needs to be scrutineered and have a fire extinguisher.
I will take the Maverick and a tow rope cos somehow I think it will be needed.:P
Cheers
Ken
ok with 5 secs looking at that dont buy resistive plugs
If you have a problem u can rectify it later as long as you find A good Electronic Teck :P
Resistive plugs may cause u to have poor ignition bud fact
Originally posted by Pva_Glue
my mate just changed his spark plug on his soarer TT...
100.46 for irridium spark plug....$$$$$ char ching!
Why ?? Iridiums last about 50K KM while NGK std plugs ( bout $2.50 ea ) last bout 15K KM.
Cheers
Ken
Cheers
Ken
Just a gut feeling there ken or what:bahaha:
I should tell Neo about it cos he would be happy to film you towing one out of the sand:p
 Share
    • FWIW, I've always found Toyota A/Cs to be much colder than Nissan ones. Even that 2024 Nissan X-Trail (that VW Australia lent to me), the A/C isn't as cold as other base model Toyota Corollas/Camrys, etc. Maybe Toyota A/C compressors are superior?
    • Hurry while stocks last! 🤣 13% points redemption on this $6000 Mont Blanc "James Dean" ballpoint pen at Yodobashi Camera in Umeda, Osaka
    • It's not that at all....I just love the R chassis too much to keep racing it! Absolutely impossible to fix the damn thing if I bend it.... That last off I had (when I neglected to do what Kel said), we removed a gum tree with the side of the boot....needed a new rear quarter, boot lid, floor straighten, rear bar, front bar, both front guards, radiator, bov return and I still haven't got it back for a proper alignment to check it is actually straight again). There are just too many ways in tarmac rally to do significant damage to a car that you can't really get parts for.
    • Now I'd said earlier I'd checked the fuses, and per @Stick180's suggestion I checked them all again. The check was to use the multimeter in continuity mode on the top of each fuse where the little metal tabs are available for that purpose. All good....except that very "A/T Control" fuse was actually blown when I pulled it out and looked at it. Put it back in, tested it again, there is continuity to both sides even though the fuse is blown. I'll need someone smarter than me, but my suspicion is that I was getting a circuit through a power supply, through an incandescent globe somewhere, to earth, to the shorted wire and back to the other side of the fuse, making it look like the fuse was OK when it wasn't....please anyone that understands this f**kery explain it to me. Bottom line....that suspicious purple/white wire, in an undamaged factory loom, that goes to the the wrong place in the fuse box has a dead short to earth, confirmed from both ends.  How a single wire in a factory loom can be shorted, especially the best protected loom in the whole car (underneath the top of the dash) is going to keep me awake at night because surely whatever caused the damage has (or will) damaged other wires in that loom too. So, to finish this long and sad story....cut the purple/white wire where it exits the fuse box, ran a new wire from there to the ECU loom pin 31, fired it up and drove happily into the sunset. Only 4 days of head scratching and peering into footwells to get me there. Another collection of wire removed (in addition to the earlier photo) and a bunch of 10a fuses that gave their lives for the trouble shooting....thank you for their service.  And, since the car was in the shed I resealed the cam cover (first time I've ever had a new seal leak on an RB, but the Stagea is that kind of lucky), and I put in the boost doc cam splash plates to try and turn down the blow by a bit while I was there. Which, was all good because it also let me find the slow coolant leak, turns out it was from the turbo water supply which I nipped up again (the banjo bolt got new washers, and I tightened the hose end and hose to banjo fitting while I was there)
