Whoretown WA
skyzerr33
 Share
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
ok with 5 secs looking at that dont buy resistive plugs
If you have a problem u can rectify it later as long as you find  A good Electronic Teck :P
Resistive plugs may cause u to have poor ignition bud  fact
Must be why Steve said not to go for them.
having said that, it seems to be against the norm but I trust his experience.
Plus for the $17.50 they cost, who cares if I need to change them for the others.
BTW - he put me onto 6's, not 7's as most other people use...
U reckon Iridiums last that long on a boosted car Kenny?
WRX's recommend every 50,000km but some of the ones running higher boost need them earlier.
Cheers
Ken
But you need resistance plugs if the car is electronic computer managed according to the tech article.
Or have I missed something ?
Cheers
Ken
I got CC under control btw kENNY ;)
Yea , riiiiight.
Is that why he came in here last night looking for the poof in the cowcatcher R33.:P
Cheers
Ken
Yeah go the colder plugs
Not so easy to start in the cold just pretend ur startin a carbed XD
hehe
But it helps stop pinging :P
errr 6 is hotter than 7 . NGK goes the other way to most heat range spark plugs.
Cheers
Ken
Cheers
Ken
You're right ken - i might go get a set of resistor ones before i put the car back on the dyno - then i can compare them to see if there is a difference whilst the car is on the rollers:uh-huh:
How does it work then - i was told to gap them to 0.7 which quite small.
Does this mean i will get a hotter, more intense spark?
What is the normal school of thought when you increase boost?
LOL what was that about?
Not quite ( poetic license it's called ) but he did come on with an attitude asking if you were here.
Cheers
Ken
 Share
    • Great to know! The guys from The Skyline Shed are going to sort it out and send what I ordered anyway. Turns out their supplier sent them the wrong stock.  But it's good to know I "can" put this in if needed
    • You do not need an LSD oil in any stock (non-GTR) diff, even if it is an "LSD". This because none of the (non-GTR) LSDs are clutch/friction type LSDs. Either viscous or helical - neither of which require an LSD oil.
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
