  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
How does it work then - i was told to gap them to 0.7 which quite small.
Does this mean i will get a hotter, more intense spark?
What is the normal school of thought when you increase boost?
Gap to .7 or .8 mm cos most of the modern plugs gap to 1.1mm hence the 11 on the end of the plug number.
The large gap is what gives a bigger stronger spark because it makes the coil build up a larger voltage to fire the spark across the gap.
The trouble is with turbo engines running larger than stock boost will blow the spark out while it jumps the gap ( simplistic terminology ) hence the need for a smaller gap , which then gives a weaker spark and is the reason why splitfire or cdi type ignitors are reqd on BIG boost engines.
Got it ?
Cheers
Ken
I think he was annoyed with how you addressed his indescretions...a little more tact would have been appropriate
Nah stuff it, just walk over and deck him. Hehehe
Tell us first so we can set up seats and get the beer and chips out.:P
Cheers
Ken
Got it ?
Cheers
Ken
Cylinder heat causes injector fuel to ignite before the spark flashes over :P
Thanks Ken - I had heard about the spark being 'blown' out.
Good work macka - blamed the wrong bloke...you are a tool (7/16 combination ring spanner if I recall):bahaha:
Maybe u should read more carefully,
I asked if he was the guy who hoons around my street picking up some girl he said yes
Im not going to change my driving habits because thats the way i drive and thats not going to change...
I accused no one
This plug talk is doing my head in...
So if I reduce the gap I should use a hotter plug to keep the actual spark the same?
Why do people go colder in most higher boost applications?
Colder plug means it will take heat , boost and thrashing better without melting or dropping the electrode off.
A hotter plug is used in colder conditions to aid starting or is used on a worn , oil consuming engine which would foul a colder plug.
Phucked with your head enough ??
Cheers
Ken
Anyway - who cares...
ZACHARY !!
I sure as shit don't sherlock.
Though if that spanker next door with the new loud exhaust on his rex goes belting down the street one more time....
Cheers
Ken
Right - almost done...
What this is telling me is that I should have gone to an NGK 8 (or stayed with a 7).
Micko , what plug exactly did Steve recommend.
I have checked my reference and Hendo told me to use
BCPR7ES -11 and gap them to .8mm
Cheers
Ken
PS I have and they work fine.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
