yes it was sad , they all asked how there times were and I said that Stewie in a stock std road GTR with crap tyres ( who was instructing today btw ) posted a time about 2 secs quicker than the best rex they had there.
Hate to burst the bubble but they ain't that quick and under steer too much:D
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Romour has it that if the weather isn't too bad tomorrow there might be a cruise happening.
If so, are you going to be able to make it?
btw - I put some BCPR7's in today. Car feels stronger, just gotta be careful not to get carried away with the higher rev limit...
No worries Adam....
Cheers
Ken
not much bud - just got home from watching the new matrix movie - i loved it.. everyone else hated it.. wierd... i guess it wasn't a holiwood formula movie so it didn't get props from many...
u guys have that dinner tonight?
somehow i don't think the weather is going to get any better bud...
so did you change the exhaust timing with the gear? think it makes much diff? it's hard for me to tell cause i did the elec boost controller, dump and pulley all at the same time..
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
