Whoretown WA
skyzerr33
 Share
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS500
hi guys,hey anybody now of a good gear box to put in my car that is 5sp and not $9000 ie ppg that will hold the hp
Who told you 9K for a PPG danny ?
Cheers
Ken
Originally posted by GTS-t VSPEC
Hi Micko, Danny, Jason and Troy.
Danny, you can do what ever you like in this thread. What's happended with the Schlack box?
Err , that's Challack box , Shalak is close to a clear paint. hehehe
Cheers
Ken
ps , check the thread you posted in re. forks pwptpf.:P
Steve was saying there are only 3 manufacturers in Oz, and there all about the same price.
three manufactures in OZ who are close and one who is bend over expensive ( Hollinger )
Cheers
Ken
Jason, We'll have to come up with plans for you new shed:D
Hi Ken, How are the WRX's coming along, whats the next major event?
Still stripping proof coat off the floor, what a ****ing job.
Am going to Speedworks then CRed tomorrow so get a day off to let my muscles heal.
Cheers
Ken
race torque $7500 box, $1300 forks,$300-500 fitting lots of cash and all the ones i've seen have blown
Yea , with the forks and build I suppose that's close.
Could try waving some cash at Kim Ledger.
Cheers
Ken
 Share
    • So, as it turns out, a new wire was the answer I went for, but getting there was not straightforward... Firstly, I'd been told before by shops that had worked on the car that it had some weird factory wiring, and I can now confirm that is true in at least a couple of places. For example....that very purple/white wire that provides IGN power to ECU pin 31.....I traced it out of the ECU loom into a connector high on the nav's A pillar under the dash, where it headed up and out of site across the dash, then back down at driver's A pillar. After trying about 8 different relays I found it coming into the back of the fuse box, and confirmed it was the same wire with a multimeter* (more to follow on that.... So, which fuse is the ECU IGN power connected to in my car?  Very top right, labelled IGN (good), 10A (good), Auto Trans Control (WTF?). It's not impossible it has been f**ked with before, but if so someone removed the pins from the back of the fuse box and moved it somewhere else, noting an AT control fuse would be functionally useless as the car was auto converted to manual long ago. It is not simply a wire cut and joined to the wrong place, both ends of the wire are the same colour just one is in the wrong location (you can see there is an IGN Engine Control fuse in the bottom row 4th from the right. Note, that is the fuse box sticker from my actual car, so either I have the wrong coin holder sticker, someone f**ked with it post factory, or factory sticker does not match the wiring.....whichever option it is just plain weird. Undermining the likelihood of someone having gone to that trouble to move a power feed when everything else in the loom had already been butchered....the fuse next to it IGN 7.5a ABS doesn't even have a wire running to it....so no idea where that fuse is on this car. All strange. But not the problem with my ECU power.
    • New tank clean paint and install complete 🤙
    • I have heard the frenchys kit (with the smaller toyota compressor) performs fantastic. i havent actually gassed my system yet, so cant confirm myself..
    • https://www.efisolutions.com.au/injector-lower-manifold-collars-adapters-r33-a32-y?gad_source=1&gclid=EAIaIQobChMIjpXb2aLaiAMVYcA8Ah1zkg6JEAQYASABEgJzG_D_BwE
    • correct Ive moved to a r33 oem ball joint - they are actually thicker than alot of the after market and similar
