  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
u know Paul Walker has had a Penis Extention -
lol waste of money, they only make the placid organ look thicker r longer not the erect organ haha
you could get nangkans afew ppl have had them they give good grip and last about the same as most high po tyres and are nly 189 fitted at most places
I was out driving this morning in my company car and managed to get a huge flat tyre.... You can just about put your finger in the hole its that big..... ohhhh and changing tyres on the new fords are interesting... The spare is actually under the car and you have to use a wynch ( sp? ) to lower to the ground....
yes i would Troy - but i dont think i would put up with him much after that haha i dont like a guy that uses more hair care products than me haha
Turbos yay. U need a bigger one :cheers:
Chaos thats sweet.
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
    • Have you found that you have to tighten your alternator belt once in a while? Mine has started to squeal again after the mechanic tightened it roughly a year ago and the engine starts up slow if I don't start it every day (think the starter motor is going out). It used to be if I don't drive it once a week I'd get a quick squeal on the belt but now it's every day or every other day. I might make a post of the start up sound.
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
    • I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
