  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Heheh thought so, i peel em, cut em in half and wash em in cold water to stop the crying thing.
I figure ure talking about cutting along the grain instead of across it like i do but its the only way to get finely chopped onions.
Anyhow........SAUWA huh? that could be interesting. Nobody nominated me though :P j/k id be too slack for the job anyhow. I reckon ud be good at being the treasurer eh Paul. U might remember AW-11? hes the treasurer for mr2 club wa and he reckons its a bit of work.
ok - cut an onion in half. Lay it flat on the board and make cuts long ways down the onion (keeping it all in one piece) then you cut sideways through the middle (along the same plane you would have cut the onion in half) then you chop the onion working you way back with your fingers.... you will never get the juice on you. And This does NOT make sense what I wrote hahaha
Originally posted by Sneeza
We can have a dinner party!!! Niz and me and wear aprons and serve everyone dinner hahahha like house wives
Nah Paul looks better in an apron than me - i'll pass haha
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
