nah biggest thing ive ever "borrowed" was a candlelabra from Burswood :) u gotta have momentos! :)
Dyno day hmmm i want my sticker so i might make an appearance n grab it and then go croozing with Liz - they are talking about the club then arent they? oh well i dun care i f i miss out on that - to me a club makes things more political - i have enough politics at work!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
niz - u can pay at east perth, but if it's past the date on the final demand notice u gotta do it at the court.. me done it a few times now to buy extra time.. :)
me off for some lunch.. got no work on so might make it a long one.. :)
back to whore yas later..
a big hoity toity candle stand Bam :(
someone remind me in half an hour to do my time sheet :)
oh well paul - i think your current driving is boring too - so we ar equal :) i almost said to u last night "for god sakes pull over and let me have her" haha but thanks for your advice n explanations - im happy now to know it was just me being a fussy bitch :(
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
    • Yeah, they'll find anything they can. "Oh aftermarket ecu, that doesn't comply with emissions" lol.
    • See, I still thought it was 10 posts, and she was at 7 so I couldn't be bothered going in and fixing it when the fix was to simply post 3 more times. 8 more times....perhaps I should have.
