Originally posted by Micko
How many k's tonight ken?
Getting the ecu tuned tomorrow?
Let us know the outcome eh?
Nope , run in and been at Lumpy's getting the chip re rit for a 7500 rpm revlimit and plenty fuel
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by zanda
checkin up on your dafaming ass!!!
hey ken, rob, micko.
hey ken,
how often do good deals on 2nd hand racing seats come up on your auction site?
Plenty on the jap auction but shipping is the killer.
Paul , am doing the Full Monte rally which is like the classic rally but 1/2 the price.
Cheers
Ken
Originally posted by GTS-t VSPEC
Alex, It's only defaming if it's not true:p
Phil, I ain't scared:D
Ken, How many K's till you can let her rip?
Already have , 1000km and I clocked that up last night after 3 nights cruising ( !! ) the freeway.
It's 69 km from roundabout at Baldivis to Hodges dve.
Cheers
Ken
Ken - no autronic yet?
Nope cos there's not time to tune it.
Paul the 7500km was put in tomight after I run it in at less than 7K .
Long process involving lots of part boost , 3 , 4 then 6 k rev limit and other crap.
Feels strong so may have been all worth it.
Cheers
Ken
Ken, Sounds good, wish I was there to film it:( Good luck with it though, is the Mrs navigating?
Nope this is a seriuos navigation event and I would prolly abuse her.
Got some dude who had the 1/2 entry fee.
Cheers
Ken
Ken, It had better be worth it after all of that:D What does the engine bay look like? Nice and ricey?
Yea , pretty blue cover and polished intake and terb pipes.
hpc type coating on terb exhaust housings and manifolds.Works well , bugger all radiated heat.
Cheers
Ken
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
