  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
not much, had a spare bumper ready to go, and they did a bit of impromptu panel repair in the shed to make it look semi sorted, someone mumbled something about it hitting a pannel shop ultra early tom morn before it gets loaded onto the truck, but it wasn't to bad, nothing a ratchet strap a hammer and some rolling of the car backwards to pull stuff back into shape didn't fix..
Originally posted by GTS-t VSPEC
Ken, You not busy at Maximum anymore?
Always busy but always keen for variety ( in job, cars and women.... ):P
I only work subcontract so I come and go sort of when I want
Cheers
Ken
Originally posted by XRW
let me just print a copy of this for your wife, what was her name again ken? :P
Let me see..
What shall I tell Jules about the deep and meaningfuls and how sleepy they make you ...:D
Cheers
Ken
Originally posted by Micko
No Paul - danny never called up about the pipe
Ken - you checked if you got one?
Micko , I have pretty much all the terb set up off the old ones so I assume the pipe you want is here.
Don't know if it's bent though.
Cheers
Ken
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
    • Oh man... I've been here, that's for sure. I love my ugly but still functional headlights that can never come apart again.
