Ken not on the net, i do have them here in an email tho so ill send them in a sec..
as for the series 6, yes i belive so, but if they arn't next year they will as they are opening up to grey imports provided 200 or more have been rego'd here, so series 6 should be a goer..
you should have email in a few
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ta .
Cheers
Ken
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
    • Oh man... I've been here, that's for sure. I love my ugly but still functional headlights that can never come apart again.
