  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah still at work :) ..... im just getting tired of the whole situation of my life .... work, home, relationships that are kinda non existant anyway.......... just want some order and stability instead of this constant messing around im getting from all sides!!
hmm seems I'm at about the same point. Am seriously considering that I need a holiday real soon to get away from work, family and pretend relationships... my close friends have been the only stable thing lately...
Though alot of my situation can probably be attributed to my attitude.. I guess I have to stop waiting for something to happen and make it happen....
The car is ok.. Low compression on number 3 cylinder, but the car makes the same power as before so I'm thinking it's been there all along. I need to get the injectors flow tested to find out if they are the problem. Am going to try to get it done this week...
why is it so hard for people just to be honest with us and tell us ..... i mean even work least if they tell me when my finishing date is officially then i have something to work towards :)
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
    • Oh man... I've been here, that's for sure. I love my ugly but still functional headlights that can never come apart again.
