yeah i was on a strict diet too - but i got depressed and had a sausage roll n cherry ripe ..... see if i can save myself at the gym tonight :D ..... must admit sausage roll tasted bloody good!!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i dun like the church - Rise is ok depending on how ya feel - Metros is good now!! its packed and it plays RnB. But i love the Deen pity its only open til 1am :D paramounts ok if your extremely drunk and dont care its dodgy haha.
Donald Rumsfeld died and went to heaven. As he stood in front of St. Peter
at the Pearly Gates, he saw a huge wall of clocks behind him. He asked,
"What are all those clocks?"
St. Peter answered, "Those are Lie-Clocks. Everyone on Earth has a
Lie-Clock. Every time you lie the hands on your clock will move."
"Oh," said Rumsfeld, "whose clock is that?"
"That's Mother Teresa's. The hands have never moved, indicating that she
never told a lie."
"Incredible," said Rumsfeld. "And whose clock is that one?"
St. Peter responded, "That's Abraham Lincoln's clock. The hands have moved
twice, telling us that Abe told only two lies in his entire life."
"Where's Bush's clock?" asked Rumsfeld.
"Bush's clock is in Jesus' office. He's using it as a ceiling fan."
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
