  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
my car needs its suspension upgraded to somehting a little stiffer, my brakes could do with a little bit of upgrading, and the powerfc, also the paint needs to be really touched up, the spoiler, front and rear bar, bonnet and drivers door need respraying....... probably should get the whole thing resprayed but i dont think that they could match my colour ;)
i want mine resprayed - a metallic purple - i wanted the R34 metallic blue - but i saw an R33 in that the other day and i didnt like it!!
Really i would like a colour that is like a cherry red in some light and a black in other light .... u know kinda chamelon but not ..... be way expensive tho!!
i think they have a name for it, like harlequin or something
i dunno, im pretty sure theyd be able to do it, i doubt it would be THAT expensive, i mean compared to other things
it was gonna cost like 600 dollars to redo my back bar and spoiler and touch up the bad stuff on the other parts of the body
but it would look shit with little bits done and little bits left fine
so it would be better to get the whole thing done in one hit
slip in qld just had his r31 resprayed, i wonder how much that cost him, i dont want a shit job done either, i want it done well, not with trims sprayed when they shouldnt be ect
i saw a 300zx resprayed, looked great, get up close, they pretty much taped the windows and sprayed everything, even the door locks
Hiya Everyone :wavey:
Quick question.... does anyone remember seeing a picture posted/linked to on SAU of a black Stagea with a R34 front on it.... I believe the car was in japan..... I remember seeing it ages ago and would like to find it again....
i hate xmas time full stop, more of that time where everyones so happy for nothing
theres no reason to be happy its just another excuse to rush out and buy gifts and crap, and theres always the gift that keeps on givving, a lovely dint in the back of ya car, everytime i look at my car i get a little angry
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
