  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
me need to move house so i can drop the car right down... otherwise i won't be able to get into my driveway...
hit the bar hard yesterday morning.. :D left fibreglass behind.. front bar looking tougher and tougher now tho.. hehehe
nah - can't.. it's the kerb up from the road.. :D
engine is going fine.. i think the low compression has been there all along cause it still makes the same power. Am getting the injectors pulled out when i get back and flow tested to see if they caused the problem...
bam - bummer.. was hoping one of you guys would wanna come with me...
might ask my old man if he wants to come along.. :D
    • Yea my question was really relating to having a big stall converter and it's interaction with that. Why would BMW not just put a 5500 stall converter in there stock then? Then the OEM car could just launch control hard.
    • If you fully flushed and filled it's probably good for 5 years. I would not push it any further than that. Generally speaking coolant is more by time than by mileage. Rust wants to happen whether you're driving it 50,000 km or 80,000 km.
    • Modern transmissions like the 8HP lock up as low as ~12 km/h. And they will stay locked even with full throttle in gear. Far, far cry from the days of 3/4/5 speed automatics when they only locked up on overdrive gears and even then only if you didn't put too much torque through it. Manual transmissions are pointless unless you personally enjoy shifting gears.
    • I read on YouTube that the neo has 2 bleeder valves? Can't see anything in the manual though
    • The only other time I changed it is when I noticed it had become discoloured after a few track days (it was .. yellowish). So I drained and refilled the rad.  I think most people are in this situation. It's not like the car ran any cooler after I changed the coolant either. I'm gonna go with "If it makes you feel better, change it!"
