  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul The wedding fund has robbed any chance of further mods to mine for the past couple of months and will continue to do so untill about mid October, then a quick couple of changes will see 320 ish rwhp and it'll be time to look for a bigger car.
I think it's about time we ALL went down the plex for a shake up..
Originally posted by GTS-t VSPEC
Shan, Only saw two Skylines in one month in the UK. There into small cars:(
pffffft.. fags.
Aidwin, not exactly sure yet, there's too many on my list. Gotta do some homework.
Paul. yep everything is going well so far.
As long as the honeymoon goes as planned, then putting up with the misses through all the planning will be worth it. Never seen her stress so much. She didn't want me to put a Wolf ecu on the bridal registry though..... the bitch.
Micko.. really.. what could possibly go wrong.. :-)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
