  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah Richie SAU has their own portable laundry mat ..... Paul has the washing line .... Cam has the ironing board :)
haha Dan :D she doesnt bite .... well you can tell if shes in a bad mood - its the only time her car gets a thrashing!
im not being bitchy! haha paul remember that Silvia with your rims on it on Saturday .......... :) ....... *hides from a slapping*
Hmmm i might put a more fancy rear wing on mine .... veilside or something ..... need to shop around .... then intercooler then getting rid of Gay Holden Clubby Exhaust *see i even call stuff on my car ghey ... but thats ok cos i didnt stick that exhaust on so it in noway reflects my taste!*
no probs Ross - you mustve got thru that novel in record time ;)
oi richie when ya ready to buy the front mount let me know .... ive discovered if you go into a shop to buy two of something they tend to be a little nicer price wise :D
Originally posted by Nizmo
oi richie when ya ready to buy the front mount let me know .... ive discovered if you go into a shop to buy two of something they tend to be a little nicer price wise ;)
hows this i can get a 's type' HKS kit for $1400
or the Trust GReddy VSPL for $1550
just need the cash....:uh-huh:
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
