  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Need to VENT!!!!!! Just found out someone I had a lot of trust and respect for has ripped me off big time. The details are not important, but when you respect someone, you sort of expect a mutually respectful relationship. This person must think I am so stupid. They don't know that I know yet, but it won't be long.
The biggest way of hurting them is just to let them know I have no respect for them. I do play stupid sometimes because some people are more comfortable around people who are not as intelligent as themselves, (ego) and maybe it is my fault for doing that.
It makes it worse that someone would take advantage of a friend just because they think the friend would never know.
NOT HAPPY JAN!!!!
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
    • Update from today; Hard work was completed today behind a computer... Ha ha Hardlines for new fuel lines ordered, and fittings for it to connect up too. Banjo fittings for owner steer ordered too, will be AN fittings. Ordered all the weld on fittings I need to build the PS reservoir too. Only things I'll need left for power steer is a couple of off the shelf fittings for the pump, and to build 3 lines.
