  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
i know i just want someone to lean on at the moment ..... noones there.
Hmmm , Cam's right.
There is a lot of people you can ask for some comfort. Depends on whether you want a friend or a lover tho...
You are only 20 and not displeasing to the eye so I would not worry and if you call Andy's protective , putdown style true love then I am a little worried about you.
Cheers
Ken
lauren so make your own plans and tell them its your party etc etc
bam we already do fall under that scrutiny and we can become a club when ever we want.
We have all the legal documents, I just have better things to put my money into atm, we want be getting cams affiliation in wa as its to much hassle and doesn't work with the way we would run are club and cruises etc.
Troy i always mean to donate considering how much i use the forums buts its something that you go - oh must do that - and gets put on the backburner for some reasonor another ..... will get my fat ass around to doing it one day tho.
Ken yeah but even Andys over protective ways can be a little more nicer than some other peoples dont give a phuck ways .... if you know what i mean :D yeha i know im only 20 but we all get a bit despondant and lonely sometimes.
ive been proactive enough in my time ..... a little too proactive .... ive done most of the stupid things and when i get like this im just likely to go back doing them again. Im ready to tell them to phuck off but it's just going to cause a whole load of shit between mel and me and i'll just end up with nobody to party with saturday night .... sit at home doing nothing like i did this saturday night :D
yes how did you go yesterday ken?
Hmm , might start charging money for rides. In the car that is ...:D
Got 4th o/r and 2nd 4wd behind Kevin Ledgers wrx racecar , a formula super vee and a track orientated westfield.
I was the first real roadcar and that's my excuse.
Niz , check your PM
Cheers
Ken
just been talking to micheal aka boxhead on MSN .... what did he do wrong ... hes not a bad bloke!
He might be alright but his constant refresh posts and arguing when someone queried the total uselessness of it all got very tiring.
His * if you don't like it **** off* attitude obviously pissed off enough people.
Cheers
Ken
Turbo's good lauren... just need to finish the project off and throw more money at it :D Really shows the need for a good ecu and some injectors and I think I need to get some really good brake fluid into the car now, the fluid makes a huge difference I am told, already got bendix ultimates on the front.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
