  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
cool that's good news dan!
yeah niz, Im afraid so. Ive got a list of things a mile long too......
* clutch
* Fibreglass fenders / or new 1/4 panels to accomodate the wheel offset
* Wolf
* flywheel
* fmic
* fabbed up plenum
* fuel pump
* regulator (mount up!)
* and ultimately a nice phat t3/t4
I also have a dream of going the Rb30det. which I suppose should happen after the wolf and fmic, but before the plenum and turbo.......
...but its all a pipe-dream with the repayments Imk gonna be making.
cool what intercooler you going?
zorst n cooler are on my list as next :) as well as EBC - that dodgy bleed valve of mine i wouldnt be surprised would be causing a few hassles with my car - i could be wrong but that thing is so homemade and dodge i need to replace it ASAP.
niz - when youve got money saved up, tell me. I can give you some advice on a good person to do exhaust and fmic work cheap.
If you're worried about the boost - GET A GAUGE.!
even if you do it dodgy like me - which is semi temporary, at least you will know what is going on!
the splitfire ones are undr a hundred bucks and are accurate enough to use on drag cars. they even sell them off their own website - distributer direct prices. yeah baybee!
thanks Alex will do ..... jash will hopefully do it cheap for me otherwise.
morning brett :)
gotta go pay bloody insurance on saturday morning .....broke lauren :)
2 weeks til my last day too ..... yes my new last day - god knows how many "last days" ive had in this place!!
Looks like saturday's are going to make us both poor....
I want to pop into Xspeed and book a major service and then drop in next door to the spoiler shop to see if they can repair/clean up my front spoiler..... should burn a nice little hole in my pocket....
ahhhh thats right .... Lauren puts zorst n FMIC thoughts outta her head when she remembers the state of her rear spoiler *sigh*
i gotta make a visit to the spoiler shop too - but i probably wont til i have a permanent job!
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
