because i am a temp and not a governemtn contractor cos they are too tight arse to make me one cos its going to cost them around $2K (thats what my temp agency will slug them to make me one)
Besides im so happy to be the other side of the building to those bitches n barsteds :) i really like who im working for now!!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ohhh I find it all too confusing..... maybe because I don't work in a government sector..... to me once a business has trained you to do a job and you can do it well they will not want to let you go just so the can start over again training someone else to try to do a job you can already do.... does that make sense? :)
Alex, No got back to work Biatch :)
Sub, :wavey:
Brett: Govt, Private - whatever - in my experience you get screwed up the butt by all of them - its just the govt will give you more money to do it.
no opposite Brett - completely Opposite ..... Level 2's here (which is what i am but im casual) Earn 27K+ you have flexi days off as well as your normal holidays etc .... but you are only employed for 3 - 6months at a time then they'll decide whether to keep you or not - and a lot of people here are going thru the process of reapplying for their jobs
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
