  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey I have known about this for 3 weeks before i have said anything... I am past getting rest... but thanks anyway. :)
I have been too ashamed to say anything, but I can't hide it forever. It makes me sick to think that the neighbours saw the car being repossesed.... they prolly think I am some poor arse.
I just can't explain how I am feeling - I act all happy and bouncy around work and everyone, but inside I am like paniking or something... I know its just a car, but is just my stupid personality where I worry too much!! I would love to get the car back, but its the money that concerns me
I get like that too when shit happens. on the oustide your happy, but inside its all you think about. it just eats you away and makes things a lot worse. On the other side, you have a damn good reason to worry
The car can be replaced (but then again, thats YOUR car), but like you say, its the money (which if worst comes to worst, im sure you would see again (although probably down the track))
Whats his family like with teh situation??
his family are disgusted that he has done this - they are trying to help sort this out as much as possible. Which I am thankful... but at the end of the day, thier son is an adult and they are not responsible. But I have been advised to send a letter of demand to ask them to pay.
I know what you mean adrian!!
i often come home late at night (i dont finish work untill 12 at the earliest most weeknights) and they always have a sad if people drive in and out of our street after 9pm!! They hate my mates coming around, they hate loud (read fast!) cars, unless its a camry they dont want to know you
don't worry liz i get the same, i act as if everything is fine when it's not, it's just how some people are, coz we feel better if we keep things tucked away and hidden because we then think we no longer have to think about it, but when infact it drives us up the wall each and everyday after that :)
good night lizzy get some rest try to think of better things :(
adrian:p
yeah i rarely come home early :D it's always after 10 :) especially if i work then it's like after 12am :(
so nowaday to stop the complaining neighbours i don't come home lol till the next morning hehehe i go and terrorise my girlfriends neighbours hehehe late at night :)
adrian:p
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
