  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahaha... there was work to be done, i had to save the world, if you can understand that i have to use my super powers for good, then maybe we just can't be ....be ....oh god...i can't put on this act anymore i am with spiderman now!! i'm sorry i just wasn't going to work, it never was!! surely you can see it. *cut to close up with long sad stare into foggy lens* to be continuted
how was that!
^LOL copy of me n mels emails ..... god we are sooo bored ... but its funny just had to share.
but im not .... as i said ... why take him to court ... no witnesses .... my word against his .... and im a bit shaky on some of the details cos it just all happened to quickly.
Mel's ok .... like me - would liek to do something more interesting but put ups with it for the sake of an income.
im back guys
Niz i just spoke to my mate from REVS and this is what he had to say.
"the only people that have personal details pertaining to car regos are either
the police and the department of planning and infrastructure, revs only obtains
these details if the car is encumbered and even then we would need the engine
and chassis no.
tell your friend, the first thing she should do is go to the cops as a hit and run is
a serious offence, one that cannot be classed as a spent conviction, there is no
way she could lose a lawsuit against the hit and runner "
sorry i couldn't get the info you wanted :(
Originally posted by Nizmo
Whats the point? .... i have no witnesses ..... and even some of the events that took place im sketchy on ....... technically he shouldve hit me passengers door .... but he hit me face on .... full on ... how the hell that happened i dont know ......
you HAVE to do this.
do butts girlie. you HAVE to HAVE to do this.
today if possible. even if you ring them and let them know. then you can make a proper report at the cop shop later.
apart from anything, he could have made a counter claim that you crashed into him. witnesses or otherwise, if the nett damage to both cars exceeds $1500, then the driver which caused the accident can be liable for criminal charges.
therefore, you need to go and tell them everything you know. especially seeing as he did a ruinner.
PLUS, because he hit you, if you find that your car is more fuxxed than you think, you will need to have made a police report for any court proceedings OR EVEN INSURANCE CLAIMS.
takes 1 call - do it now. or I'll spank your bottom.
LOL .... i could enjoy that spankin tho Alex.
Ok well that cop shop in east perth ....u know the big one that handles all the infringements .... reckon i could do it there? do it in my lunchbreak tommorrow or sumthin.
we both left the scene of the crime ... couldnt very well stay in the middle of a busy intersection and battle it out could we but i parked by a side street and waited for him .... he didnt show .... so i went in further and got my car outta everyones way and then started calling everyone.
Sorry Revn .... i forgot to thank you for your time and trying for me *hugs*
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
