  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
im here Angel :)
Grandparents are over .... hiding in study with a glass of wine - haha i had to drive back from the winery (them & my folks went out for their wedding anniversary) .....and my mum was pissed sitting in passenger side of Clubby ... grandparents & dad in the back anyway htis Holden Statesman tries to take me on and mum says it was ok for me to drag :) my grandparents almost had a heartattack!! ...... i won :D but hell takes a while for the Clubby to get the power down!! so wish had my car back :uh-huh:
working on a sunday???
Phuck that!!!!
Counting down the days til my car comes back (if i only knew how many days i had left to go!!) im getting so excited ..... getting new spoiler ..... getting EBC ..... getting Gauges ..... eventually getting chequer plate ....... my car wont recognise itself :)
neither is my dad *insert whiny voice here* "but it'll be noisy and horrible ....Lyn you really dont want it ..." ... my car .... i do want it .... whether you get me a price or not its going into my car :D
Something special? hope it looks special :) yeah everyones rushing round for PAS ..... only two weeks now ..... you coming to see?
you get a day off during week to compensate? ..... not so bad then :)
dont know whether im doing the right thing changing GTR rear spoiler to veilside tho ...... i have to wonder ...... oh well just sick of looking like a clone and i guess still have GTR spoiler if i dont like veilside.
haha i'll be the tall blonde in the white Skylinesaust top and the denim shorts ...... well its me in avatar anyway so come n say hi ..... ive been recruited as one of the "promo girls" so i'll be there all day :D .... haha ive told or my mates ot come say hi .... keep me occupied :)
wonder why Nissans brought out that maroon red ...... Skylines resprayed in blood red looks ten times better ..... they are so nice :)
Browsing carpoint ........ get some nice cars on there ...... give me ideas.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
