  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
sorry for my Engrish people ...... im on my hmmmmm about tenth glass of wine ..... takes me five minutes to edit my posts and ever after that they still dont make sense - sorry.
CHANNEL NIZMO apologises for this interruption and will resume normal broadcast as soon as possible .... we would liek to thank viewing public for their patience ...... *play crap "intermission" music here" ........ and cut!
nup two ..... give me two secs and i'll drag out the two different types.
RX7 :drooling: they are one sxy car! only the new ones tho .... saw an RX8 the other day ......... mmmmm orgasmic!! just reminds me a little two much of the Honda S2000 tho for some reason.
Rb240Z .... not going full kit just rear ...... and its free so im not complaining :) ok just about to post number two but dad came in and i was showing him the two types ........ ok number two is just like Adrians .... hang on a mo.
    • The reservoir is pretty far from the pump, as others have said some of the pipe is also a rather janky power steering cooler. Find the leak. It might be the rack, might be a hose/pipe, etc.
    • looking at attached screenshot , I don’t know why there is a significant hose run for it to be looped backed into the steering   mine bas air in it and loads of it as when i power the car off loads of air come to surface forcing fluid out. I think my issue is leak or maybe hole somewhere like yours. I am going to drain the fluid and smoke test it   when i turn steering side to side it soften up little before getting hard and believe issue is air leak somewhere as pump is fine
    • It may not be relevant to your situation, but when I had the issue of air getting into the system on my GTT, I found there was a tiny hole in the aluminium cooling pipe. Enough for air to be drawn in, just not enough to cause a significant leak. Looked like the previous owner had chosen a bad place to attach the earth clamp of his welder and tried to mask this with a piece of mesh sleeving 🙄
    • Greater amount of energy is required to turn larger wheels up to speed, there for laggier. However bigger wheels are capable of flowing greater amount of air through both housings, let the engine burn more fuel and makes more power that way.
