  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha u didnt do the leederville cage thing did ya .... haha we got Matty doing the Sprinkler in there one time ... he does it so well .... just pissing ourselves laughing!!
Havent been to Leedy in ages .... used to go there a lot. Get pissed then go across the road for a kabab to sober up.
Denver i nearly fell off the stage at metros city trying to get off it haha. Now theres a bit of a steep drop!!
Niz, You love stage dancing:p
Danver, A few people are worried about results being fudged with correction factors, just wanted to be able to reassure them that the readings would be accurate.
Dan, Don't worry, I'll treat it like my first born child;)
the results can't be fudged with correction, and i wish certain workshop people would stop telling people it can be fudged, ivan isn't going to be fudging anyones results no matter who it is, he has a business to uphold, not cater to the likes of people wanting to cheat, it will be a fair and level comp i can assure you
    • Yeah do that, it’s only 120kAUD!!! You should have that sitting in the ashtray
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
