  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paul: www.seek.com.au ...... paul register for job mail .... they'll send the jobs suitable for you thru to your email each day :)
my cat wont show you the mouse because she knows if you see the mouse in her mouth you wont let her in ..... she the little bitch somehow hides it in her mouth and as soon as you let her in she spits out a decapitated mouse body plus head ..... disgusting little animal ..... then sits by it and looks up at you like - "here mum!" aghhhh then i have to dispose of it .... which zenah then changes her look to one of hurt and makes me feel guilty.
haha Dan i have a ****atoo named charlie ..... he's snow snow white ..... dont know what kinda charlie your talking about ;)
haha that'll be a short lived career *jk* ;)
this is very sudden paul - you've always said how much you like your job and that youve never had to have interviews ..... hehe welcome to the world ............. whats the story :confused: your not the kinda person to wakeup one morning and go "hey im going to do this" ....
Is it raining? Is it snowing?
Is a hurricane a-blowing?
Not a speck of light is showing,
So the danger must be growing.
Are the fires of Hell a-glowing?
Is the grisly reaper mowing?
Yes, the danger must be growing,
For the rowers keep on rowing,
And they're certainly not showing,
Any signs that they are slowing!
;) i soooo cant wait to see you in a real job ....... cos more money = more work = actually having to turn up to work! = probably overtime = more stress ............. ahhh this is going to be funny cos really when it comes to work your very sheltered!!
Originally posted by GTS-t VSPEC
I'm bored of both my jobs, all I do is whore all day, I think there has to be something better to do with my time:D
Paul you couldnt survive in Adelaide without a computer you had to borrow Lumpys - the only time we had together by ourselves you were whoring ..... you have to read every post ......
congratulations tho cos you really need to discover theres a world outside SAU
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
