  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah front indicator cover is what im after aidwin as mines smashed ..... and the panel beater seems to take his sweet time finding one :( sooo if u got one i can pick it up on way to gym
ours are both series I Aidwin - dont see any reason why shouldnt fit ..... actually might come over after ive picked up car which would be about 5:30pm ..... if the arsehole has managed to track one down & its already on my car then i'll send you a message.
Hi Denver
    • $350 for a skid pan day at EC? WTF?? They used to be like <$100? We had track days at EC south and the full circuit for $350-odd WOOOWWWW COVID ruined us all.
    • C'mon Matt, our cars are classics now... *looks at 1kg BigW bottle mounted in front of seat* ah that's been expired for a while now... 😢
    • As above, can't rely on rubber belts too much when you're hitting OVER NINE THOUSAND !!!11!! revs, so electric conversion (Astra as mentioned above) is the way to go.
    • I highly recommend spending a lot of time searching the posts here. There is literally decades worth of information here, and whatever you can think of has been done (besides maybe quad-rotor AWD into a Skyilne chassis). Like, there was someone with an AWD Silvia and a crazy built SR20, and I've personally seen an R31 Skyline (Australian spec) with R32 GT-R running gear (including AWD).
    • Dragging some reo behind a ute or trailer will smooth out a dirt road, I've used reo a few times to do unsealed road maintenance when we didn't have any plant available  It's best done when the dirt is wet though, and then you just let it dry out for a day to harden up For wetting the dirt I've used some 44 gal drums in a ute or trailer, and a water pump connected to a hose with a old sprinkler tied to the reo to wet the material down whilst spreading Basically just drive slowly up and down the road a few times dragging a few sheets of reo wired together with the sprinkler wetting it all down as you go
