  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cant decide what to build... rb20 in my 31 GTS or sr20 in my 1200 ute
so i just ordered a xmember kit for the datto just in case..
my 32 cut will be here on the 20th dec ... i know what ill be doing christmas day
:D
    • Too much work, but guess I will have to
    • qld plates “GTR R34” for sale $5500 (listed else where)
    • Or, just take PS pump off and inspect? Does no-one do this any more?
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
