  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
well i think im quite decent in the driving area ... come for a hills run in my current race spec stock as a rock vn and it will show ive got at least guts :D
all i know is i like to drive on the limit and im not afraid to push that little bit harder...... might be a good idea to do this and see how i go
Race spec stock as a roc???
Prease exprain???
No VN I know goes around corners... :) Hehehe
Cheers
Ken
avoid the hill climbs for a while then, they hurt if you pusht he limits that bit to much..
Heheheheehehe
I gotta admit , the Meelup hillclimb had me clenching the buttocks...
Jill ( red 200sx) promised that she would not return to her scene of carnage :D
Cheers
Ken
are hill climbs any worse then say a 1am run through mundaring weir road ?
Mundaring is a nice road but the trouble is unless the clock is on , you are only racing yourself.
When the big boys come, you realise you were only playing....
PS I am not saying I am a big boy ( cosa the wifa says I ain't) but a until you give it a go , you will never never know... :D
Cheers
Ken
well Ken i simply just line it up through it in and steer her through and shes stock as can be - last g3wc cruise i paced 3 ls1 powered  commodores with brakes smoking by half way.............
Tom , you have got to be kidding??
Tell you what , I will take for a run around Collie or wanners next year.
Don't want to be rude but when you are starting to get flat 67's long circuit in a road car then I will start to worry.
I don't want this to sound big headed but a lot of people think they are going quick until they go with someone quick.
Try going with Denver on a drift session or Brett Morse in a 2wd BMW against my old GTR and finishing poofteenth's behind. Man , that boy can drive..
Cheers
Ken
Oh now doubt Ken ive never been on a track before where u need to know how to really drive....
personally however ive always felt like i know how to push a car hard - its my pashion to drive cars and drive em hard.
"you have to be kidding" - almost the same thing the owner of one of the cars said to me that night :D
Tom , don't get me wrong , I am not knocking you.
It's just that every young person who comes to me seeking training/guidance/insparsation/encouragement thinks they are the next Colin Mcrae/Michael Schumacher/Denzo.
They think that they are the best and what they have done is unique.
I can tell yo that I did not invent it and am not the best , but neither are you.
What I am saying is that with age comes experience and knowledge and I can tell in 10 minutes if you *have it* or are just like a lot of the rest of the young people that think a power slide is actually drifting and an apex line is something that a drunk chick gives you...
Cheers
Ken
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
