haha at a cruise we will meet... I usually get there somehow!! hopefully next time I will have my baby back.
nah I dont always look on the positive side.... sometimes its too much - but i dont know, i have a drepressed friend, and I dont want to end up like that
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
IF THEY DONT, TELL THEM YOU HAVE LINKS TO AL KAIDA
money come out quick smart, and a free trip to asio secret head office in perth
so devil those blue neons in ya pic is that ya sisters
astra
the nismo key is like 90 i think. the gtr key is 45 or 50
i can see how much a black plastic headed nissan key is for you if you like, then you can get 2 of those and get them cut etc. and that should look nice and standard. also let me know if you wanna get an alarm etc. i can hook you up there also
    • Cheers Lith! You're right, it's entirely possible that there's other reasons for the low compression. It's off to the shop soon, skipping borescoping etc and just getting it out and apart, we'll see what it looks like then.
    • Wanted to clean the film behind the triple gauge so the lights show through better.  Progress so far….
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
