  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey joe. I saw ur car on Friday night. It was outside maccas in currimbine.
Scruffy (my new birdie) is trying to crack onto troy on the couch i think. Cheaky sod.
Hes got a leash. He doesnt like it much though.. but will get used to it.
Cool... I wanna have birdie... :D leash? hahhahaha cant be too careful
I tried stingos, vinigar, but they didnt work. Cold drink and an icecream on the sting helped. Aparently it was a blue bottle.. but i know what they look like and it wasnt one of thoes. I think it was a relative of the box jelly.
but joe. IM NOT PISSING ON IT.. it was on my back.. that would have kinda been hard.. Troy offered but i slaped him.
should da taken it...:D
ahhaa
piss up at the cott with a twist. :D :flamed:
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
    • Ran into this bloke trying to give Oscar some advice pre-race today.
    • Yeah I've personally seen the RB26 pull 30 degrees of ignition timing out of the base timing map if the ECU detects a cold start, it nearly starts misfiring because of it around 2000 rpm and it feels like the engine has no power. I'm just surprised that modern OEM control strategies are actually trading off efficiency for in-cylinder emissions. I would expect something like aggressive EGR dilution + tumble generation valve use to improve EGR tolerance to reduce in-cylinder NOx + HC from crevice volume while also reducing throttling loss vs pulling out some timing if not knock-limited.
    • *** DATE CHANGE *** Date has been changed to Saturday 17th May. The time and location is still the same!
    • You're more than welcome to - looking forward to meeting you!!  The turnout depends on the event and location... Pizza Runs on a clear night can drag out a decent crowd!
