  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
this is what he got in
BANZAI MOTOR SPORTS
ITEMS IN STOCK:
•HKS GT2530 BB TURBO FOR RB20/25 GOOD CONDITION 320HP $1,650
•HKS GT2530 BB TURBO BRAND NEW 320HP $2,300
HKS T3G NON BB TURBO TO SUITE RB20/25 RATED SAME SIZE AS GT2530 $800
•HKS T300S (T4 STYLE FLANGE) GOOD FOR 450-500HP SUIT 2LITRES OR UP $1,300
•HKS T04R KIT FOR RB20/25 650HP KIT INCLUDES(HKS T04R TURBO, HKS CAST LOW MOUNT MANIFOLD, HKS EXTERNAL WASTEGATE, GREDDY TYPE R BOV AND SOME ADDITIONAL PIPING)
$2,600
•2X HKS GT2835R TURBO’S BY THEMSELVES EXTERNAL TYPE
$3,500 FOR PAIR OR $1,800 EACH
•HKS SQV NEW TYPE BOV KIT FOR RB20 GOOD CONDITION $310
•HKS USED T04R TURBO BY ITSELF 650HP RATING $2,000
•HKS NEAR NEW STEP II GTR CAMS 264IN 272OUT $800
•HKS USED MUCHROOM FILTER $90
•APEXI EL SERIES II BOOST GAUGE 60MM MECHANICAL NEW $220
•BLITZ SUPER SOUND BOV USED, KIT FOR S13 SR20 AND CA18 $220
•GREDDY TYPE R RACING BOV USED KIT FOR GTR GOOD CONDITION $350
•GREDDY V-SPL INTERCOOLER KIT NEW FOR S13 $1,550
•S14 STANDARD JAP SPEC BALL BEARING TURBO AWSOME ON CA18 OR S13 SR20 $800
•1JZ 2X STANDARD CT12 TURBO’S CHEAP!!!!! $400
•6X STANDARD R34 GTR INJECTORS, GOOD UPGRADE ON CA18 ETC $650
•NEW Z32 AIR FLOW METRE $450
•S13 STANDARD SR20 T25G TURBO GOOD CONDITION $400
•HKS 850CC INJECTORS FOR 1JZ/2JZ WITH FUEL RAIL $900
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
