  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
hey Dan isn't yum e on an exhabition tour this year and not elligable for the points?
OK number 1 guys superman, batman and spiderman aren't real people!! we all know wolverine is the best! :P:D :shake:
number 2... what do you mean Paul, we had a new events co ordinater so we basically had about 2 weeks to plan everything thing is though in that 2 weeks he did EVERYTHING.. lighting the works all ihad to provide was my car and sheets... he did promo girls aswell! for his first effort i must admit he did leave it late but he made up for it by organising everything. Yeah Cam was away from me but he wasnt in the RB section.... auto salon tells us where our cars will go and how much space we have.
3.. yeah i do see a lot of porsches and stuff but i just feel a whole lot safer... 4 weeks ago one of the girls in here bought a brand new gold echo. parked a few spots behind you and forgot to put her handbrake up..... SMASH!! rolled reverse into S15 silvia:uh-huh:
i thought R33_Cam was in the all4wheels display??
Oops was meant to say WASN"T in the RB display.. fixed now :P
The guy frrom smallville will end up wearin his jocks on the outside of his leotards if not that then more than likely on his head... it's enivitable... you've seen the superman movies....
Smallville superman is a fudge packer......
Guest
