  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
But this is a problem that was there when the shockies went - so i thought get shockies, get alignment, get balance and it will solve the problem but it hasnt. So its not a new thing that has just happened recently since balance and alignment its been something thats been around for about 2 months :)
Originally posted by GTS-t VSPEC
Ken,
It's pretty hard to phuck up a balance, even I can use a balancer machine:D
See'ya:burnout:
Actually on mags it's quite easy to stuff it up.
They could have put the weights on without cleaning and this causes em to fly off.
As most shops dont use knock on weights , then positioning on the inner rim is critical.
Would you like a small wager that I can change the problem by swapping fronts to rears ?
That's as long as Niz hasn't left any important details out?
Cheers
Ken
Details like that!
Has this been doing it for a while ?
Does the steering wheel shake side to side or up and down ?
Cheers
Ken
Ken,
My mates own a tyre place, shouldn't be that hard for anyone who knows what there doing.
See'ya:burnout:
Paul I used to OWN a tyre shop and it is easy to get wrong if you don't know what your doing.
I am sure if I drove the car I could tell you in 5 mins where to start looking.
If you owned an Escort , you would know how critical w/bal is.
Cheers
Ken
side to side - which i guess is definately wheel related then. just pisses me off cos it is quite violent when you hit the 120km mark - which i shouldnt be doing but oh well im nauti - and thats kinda when u need everything to behave at those speeds :)
It's not brake shudder. Your car hasn't been in a crash before has it?
See'ya:burnout:
you wouldn't normally ( but who says Niz is normal ) go from 80 to 110 kmh with your foot on the brake.:)
Cheers
Ken
Yep , your learning . side to side is usually balance related , up and down is usually egged tyre/shockie related.
Cheers
Ken
accident not that i know of and it was checked out before i bought it. Ahh brake shudder - now theres something i know a little about :) im going to get new pads put on the beast soon anyway so i will get them to skim and get any shudder taken care of.
Guest
    • Hi All, I have a 32 GTR, with coilovers, hicas lock bar, exhaust and pod filters. Just after suggestions on where to begin with engine/power output mods without breaking the bank. Thanks in advance.
    • I’ve been considering one of these screens too, but I've heard mixed reviews about the software responsiveness. Some say it's great, while others mention lag issues. Before pulling the trigger, I'd check out a few recent user experiences to see if the latest models have improved.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
