  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
sorry would of whored with you guys but dad burst into the study going pyscho cos he was pissed off with mum then started going pyscho at mum as well - it was a huge domestic last night - would of kept the neighbours amused but im ok.
33Spec2,
I think there was a whole thread on exhaust sizing for NA cars. While turbo cars run best with not restriction, NA cars do require a certain amount of backpressure. So a hi-flowing 3" system might be too much for a small capacity engine (2.5L). I think the 2.25" is a good idea, it will save money still improve horsepower and sound tough. If you want to spend money then get a set of tuned length extractors, they will make a big difference.
See'ya:burnout:
The 2.25" zorst won't cost too much, bout $700, but extractors are expensive if you want proper tuned length. I'd ask a few exhaust places first to get an approximate price. All up about $1300 at a guess. Will make a difference, but still won't make the car super fast like mine:p
See'ya:burnout:
Guest
    • Need this stuff gone, prices reduced. Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $480. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $190. RB26 cams used, excellent condition. $190. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $190. All items located in South Eastern Melbourne. Please PM me if interested.
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
