  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Strich9ine
YAY!!!!!!!!!!!!!!!!!!!!!
Booked my clutch in for Thursday morning at Auto Clutch!
DCB 9puck clutch with 2500lbs pressure plate, re-machined flywheel, and thrust bearing..
so all should be right for friday's cruise.... just hope i can "bed it in" before then!
How much was it?
Originally posted by skyzerr33
that setup will be about $850 for kym dan
we should call ross and tell him what a twit kym is so he charges more hehe
AHAHAHAAHAH!!! :-)
the one that PSI did for me is 2600lbs... i have gotten really used to it now :-) i think mine came up to about 850 aswell but brett used a REALLY good quality one and is really not that hard to push in! Troy next time you hoon past gimme a call and i will let ya feel my clutch! not crutch ahahha!tell me what you think of it..
i hated it 1st of all but really am getting used to it... it's a lot different from a hyundai clutch Kim :-)
Guest
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
