  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
kyles i know its around - dads been tot the doctor whos given him real strong antibiotics he's been ordered to take if his chest feels like tis closin up - its not as bad in taiwan as some of the other asian countries anyway - im pretty sure he'll be fine :)
kyles - hes nuts so he can be responsible for anything?? hmm.. doesn't gel...
as for how u get it - out of the 18 countries in the world that have cases - only 6 have actually a link as to how they got it.. the others just appeared...
check the stats - http://www.who.int/csr/sarscountry/2003_04_09/en/
you're not safe anywhere - so why be worried.. if you're going to die - you die.. simple... :D
another $5 in the hat for words from guru cam please.. :)
Originally posted by Psiker
i agree niz. and they shouldnt leave the house if they look like they have slept in a gutter all night and been drinking bourbon and smoking camels since they were 5 :)
Psiker
sounds like half the people i work with and thats on a good day haha tell u some people i see that smoke is enough to put me off it - wrinkles and horrible skin and f-up voices yuk
Guest
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
    • Legend mate, cheers for the response. I just got the block back from the machine shop and didn't wanna go drilling after I clean it.
