  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
GTS-t VSPEC, oil catch can vs oil breather. Never heard of the distinction before. I know of the filtering kind, but sucking filtered oil vapours back into the intake kinda defeats the purpose for me. If you're going to break the law, may as well go and break it properly. :)
the IT guys have to be messing with me nobody can be this stupid - we send our conference room bookings to them - so i ask for the one on level 9 so they get back to me with a confirmation that level 6's has been booked for me and so i reply via email no no on i wanted level 9 so they get back to me saying level 10 has been booked for me aghhhh - what is it aobut the number 9 they do not understand?!
Gradenko,
It's not only designed for recirc true, but seeing as most of the oil is removed from the vapur then I don't see the problem with the recir idea.
I got to go out and pick-up our new Linux Server:D. I'll be back in 1 hour.
See'ya:burnout:
hmmm i'll pass on the boy from bangladesh thanks
high commissioner is coming - so functions have to be organised so do briefings in which we are expected to know a little bit about their country,
Guest
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
