Originally posted by GTS-t VSPEC
Ken, I hate annoying the other drivers, will only lead to the inevitable. I always make sure I have enough room and time to avoid any incident, otherwise I just back off:D
See'ya:burnout:
*thinks, is this the same guy who approached a 90kmh bend at ....err ... in excess of 90kmh ??*
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Neo
Ken
Glad that you did not use flash photography on the run this time. It makes you a bit paranoid on the freeway.ha ha
Nah , was too dark and shitty for any video or photo work.
Besides , 1hr of follow the leader is a little boring on camera.
cheers
Ken
Yes a dry day would be nice. Although a cold winters early morning is just what the old lass needs
My old lass stays in bed on those mornings and says to get your own breakfast
Cheers
Ken
Hehe, that was cause Troy drives like a p u s s y. He said: "I was doing 15km's over the limit, I'm not going any faster":bahaha:
Poor Kyles must have been bored shitless:D
See'ya:burnout:
I think it was the sideways launch and *****ff down the road on Leach hwy that woke her up from her slumber.
A set of tight buns and a nerd wars plate can only get the attention for so long...
Cheers
Ken
Guest
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
