  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah its hard ot afford these cars so young had same problem with 300ZX my parents had to dig me out of debt :D
So any plans for another sports car in future?
Hey aidwin - wash your mouth out supras are still a good car ;)
hey aidwin....I LOVE SUPRA!! if wasnt for the blind spots(i counted there is more than my FTO) i would chose a supra over a FTO:)
and Niz, what happened to ur car?
i found out this morning...my friends GTR got broken into....all glass windows smashed and everything got stolen except some thats too attached ...i feel sorry for him tho
Fresh from her shower, a woman stands in front of the mirror,complaining to
her husband that her breasts are too small.Instead of his standard response
of reassuring her that wasn't the case, her husband uncharacteristically
comes up with a suggestion.
"If you want your breasts to grow, then every day take a piece of toilet
paper and rub it between your breasts for a few seconds."
Willing to try anything, the wife fetches a piece of toilet paper,and stands
in front of the mirror, rubbing it between her breasts. "How long will this
take?" she asks. "They'll grow larger over a period of years," he replies.
The wife stops. "Why do you think rubbing a piece of toilet paper between my
breasts every day will make my breasts grow over the years?"
He shrugged and said, "Worked for your arse, didn't it?"
He lived, and with extensive therapy, he may even walk again.
I must admit, the skyline is a better car but i think the Toyota engines are better. Little bit better quality, just a bit.
Well i have to Auster but its no serious sports car. Looking at the new supra in 2 years but until then the auster will have to do.
apprently u have rev the nissan motor harder to produce the same power as a toyota but the nissan motor is built stronger - but because of top end power wear it evens itself out - what i heard anyway. Probably didnt explain that the best.
im not bad thank u ;) for a monday anyway :D
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
