  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
dont worry Dirty Joe
Next few times u wont have to pay....
Nah your cooking was shitouse
seeya
What?!?!?
Listen can you hear that cracking sound, I think you just broke my heart and feelings...:P
really was that bad? man two things I take really really seriously and cooking is one of them.... I am shocked :)
Guest
