  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by SHUTO-BOY
hey... "u gotta be smooth man...as smooth as running water"
-Bruce Lee
he also said...
I have developed new fighting position....
and
you have to be like water! put water in the cup then it will be shape like a cup, you put water in teapot, you'll be like teapot...
Guest
