  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paul
theres a bit more going on than just a bleeder in your 'bay.
thinking about grabbing one of those hybrid ebc for $300 odd. figure its gotta be a shitload better than a pneumatic valve.
adrian
yeah, fmic to come in time maybe. budget in the short term may be moredirected at restoring the sanctity of ridiculously loud music to my travelling roadshow.
might be getting a truck core cut down REAL cheapin the not too distant future, but that's the only waymy budget could justify the expense. besides, I get the feeling that fmic doesnt really make that much difference when you've only got limited boost capacity ot of the standard turbo.
Guest
