  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
well I'll be making my side of bargain Wild Turky I promised... and the Turky you will get!
You will be supprised I hope you have a cage in your house :D hahahahhahahaah
As long as it doesn't gobble , gobble , gobble too much then macka will be happy.
Abit of licking and sucking will please him even more.
cheers
Ken
Originally posted by macka
Cage ? is that for the the sphincter of the universe...
thats ok we'll all wait out the front in the bushes and come out when the parents have left....
Hasn't stopped you hiding in the bushes there before so what's different now ?
Cheers
Ken:D
Originally posted by GTS-t VSPEC
Ken,
Nothing wrong with gun-metal grey GTR's I'll have one if your giving them away:D
See'ya:burnout:
Nope , gave the last freebie to Micko.
Simmo paid dearly for his ( not ):D
Cheers
Ken
cheers
Ken
I dont knowabout sucking but it's kinda Frozen hahhah... he will get freeze burn if he touch with his body...
Paul- I thought you running your car at 1BAR!!! :D
Guest
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
