  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
and 30% less lecky as well compared to normal washers..
Im hypo.. excited that my washing machine will be delivered saturday. Ill be washing all my clean clothes on satruday!!  And i may go buy a couch and this wicked awsome beautiful rug on saturday.
read troys gonna be broke
Guest
